1995 Ford Bronco
FORD 351
  • 1995 FORD BRONCO
Transmission problem
1995 Ford Bronco V8 Four Wheel Drive Automatic
Hi! I'm just having a little problem on my ford bronco.
Every time I try to drive my truck it makes a clunking
noise. That's every time on first shift. I changed
the oil and the filter from the transmission but,
It didn't help any. Thank You!
Tuesday, February 10th, 2009 AT 10:25 PM
BLACKOP555
  • 10,371 POSTS
Clunking.
First step I would do is go under the vehicle and check for play in the universal joints, when they wear or go out they can cause a clunking noise.
Also if your drive shaft has splines on it you may have to take off the driveshafft and clean out both sets of splines and grease them up good with high temp grease.
Monday, February 16th, 2009 AT 9:03 AM
