1994 Ford Bronco noisy transfer case
128,000 MILES • V8 • 4WD • AUTOMATIC
SCOTT0024
  • 28 POSTS
warmed up at idle, transfer case has a knock. when driving the noise is still there but shifts hard through driving range. any suggestions would be helpful.
not sure where to start.
Jan 9, 2009 at 4:13 PM
2CARPRO JACK
  • 11,533 POSTS
Ther are very few parts inside at-case. You may have a chain that is slapping the case or fork bushings that are bad causing it to chatter against the gears inside. The t-case wont dictate how hard the trans shifts though, that is all transmission.It knocks at idle? if so it may be something inside thetrans instead of t-case, when not moving there are no parts moving in the t-case
Jan 14, 2009 at 11:55 PM
SCOTT0024
  • 28 POSTS
so if the t- case is not the issue, what might be the problem with the trans. we did have to disconnect the abs sensors for about a week, would this have anything to do with the knock?
Jan 23, 2009 at 3:26 PM
2CARPRO JACK
  • 11,533 POSTS
That wont do it (Abs Sensors) Could be a bad torque converter. Most internal trans problems require a tear down to find the problem. too many moving parts to venture a guess. Need to get under it and verify that is where the noise is coming from though
Jan 24, 2009 at 12:21 AM
SCOTT0024
  • 28 POSTS
Sorry it took so long to bet to your message.
the torque converter. is there anything specific to look for or check to determine if the torque conv. is the problem.
Feb 7, 2009 at 2:25 AM
2CARPRO JACK
  • 11,533 POSTS
Basically just trying to pinpoint where the noise is originating from.May be transfering through the trans and t-case, since they are aluminum, they act like speakers
Feb 7, 2009 at 3:34 AM
SCOTT0024
  • 28 POSTS
do you have any way to determine if the noise is actually the t-conv. i have in the past used a wood stick to try to pin point the noise. is this a good method?
Feb 7, 2009 at 6:10 AM
2CARPRO JACK
  • 11,533 POSTS
That or a long screwdriver held behind the ear
Feb 7, 2009 at 6:15 AM
SCOTT0024
  • 28 POSTS
Thank you, I will let you know what the out come is.
Feb 7, 2009 at 8:08 AM
2CARPRO JACK
  • 11,533 POSTS
Thx, im curious to see what it is
Feb 7, 2009 at 8:15 AM
