1994 Ford Bronco Engine/fuel
165,000 MILES • V8 • 4WD • AUTOMATIC
BORREGOBRONCO
While driving at high speeds (55 mph), I experience a high rev of the engine, like it is shifting out of gear and than goes back to normal running. Sometimes it will happen for a few seconds, than back to normal and than rev again. My transmission man says the transmission is not the problem. The transmission does have about 75,000 miles on the last rebuild. I would appreciates any insight to the problem.
Sep 29, 2009 at 9:48 AM
  • 110,251 POSTS
If the trans is coming out of gear, make sure the fluid is full. If it is, your trans mechanic needs to scan the computer to see if there are any codes. The problem lies in the trans system.
Oct 23, 2009 at 4:59 AM
