1990 Ford Bronco rear window
JOJOMOJO
  • 1990 FORD BRONCO
  • V8
  • 4WD
  • 190,000 MILES
Hi, ive got a 1990 ford bronco with 190000km on it. Okay so, The rear window on my bronco will not close. Ive been hitting it with WD40 and there has been no change. I checked the conections and they apear fine but im not sure. Im thinking it is the motor but I dont want to buy a new one. Just to find out that it wasn't the problem. Any ideas?
Monday, December 1st, 2008 AT 6:00 PM
DAVE H
  • 13,384 POSTS
Use a voltmeter to check you are getting power to the motor. If you are then the motor has gone i'm afraid?
Monday, December 1st, 2008 AT 6:06 PM
JOJOMOJO
Hey thanks il try that.
Tuesday, December 2nd, 2008 AT 12:32 AM
TRAVIS650D
  • 8 POSTS
Its probably the motor, or the switch. It sounds crazy but try this first, open the tailgate then slam it shut. I know the window on my bronco won't work if the tailgate isn't slammed shut. There shouldn't be and play in it, it should be tightly closed. Or it won't work.
Saturday, January 17th, 2009 AT 11:40 AM
