I have a 1989 Ford Bronco (full size) with the 302 V-8. I had the engine replaced 3 years ago, and hardly ever drive it. Apprx 15,000 miles light duty on new engine. (like new) Oil level got low, and damaged the engine.... the "check engine" light came on just in time to tell me... ruined engine... I could hear the knocking, I knew I screwed up. Figured atleast a rod bearing, maybe the crank. Towed to the shop... and I was told... that it was an extended rod, and not just the bearing.. and that ALL the rods would have to be replaced. An entire bottom end replacement. Rods, rod bearings main bearings crank. $2,800
Can you tell this without pulling the rod? Then, can you pull the rod without pulling the head?
I have seen engines have 1 or 2 rods replaced... not all 8... and they were fine...
I got the old " You have to replace them all or it unbalances the engine. I know the rods at the factory are not all identical, and they don't balance them there. I am doubtful, that this diagnosis could be made.. if all they did was pull the pan? I am not even certain they did that.
Dec 25, 2007 at 5:08 PM
