1989 Ford Bronco
UPSER714
  • 1989 FORD BRONCO
Electrical problem
1989 Ford Bronco V8 Four Wheel Drive Automatic
MY WIFE STARTED THE BRONCO THIS MORNING, TURNED ON THE LIGHTS, WIPERS, AND DEFROST. IT DIED. CHECKED BATTERY(GOOD), IT WILL CRANK AT THE SOLENOID, BUT WON'T TURN OVER. NOTHING AT THE KEY EITHER, CHANGED THE IGNITION SWITCH ALSO. NO POWER TO THE RADIO, WINDOWS OR WIPERS
Monday, June 21st, 2010 AT 5:08 PM
Hi upser714, Welcome to 2carpros and TY for the donation.
Do below and get back with some results so that we can pursue this issue of no start, then will get into the rest
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Monday, June 21st, 2010 AT 6:11 PM
