I have a 88 Ford Bronco II that will not go over 55 mph. It is backfiring and stutters when in lower gears. I have to get it up to 55mph in 3rd gear then when I switch to 4th if I'm not on a flat plain I start loosing speed even though I have the gas pedal to the floor. Recently I had to change the vacuum brake booster. When I removed the old one gasoline came pouring out of it. I looked inside of it yesterday and it is full again. I have changed the fuel pressure regulator, the pcv valve, the fuel filter, the air filter and the spark plugs. I also took the catalytic convertor off to see if that would make any kind of difference and it didn't, it just made the truck much louder. (I immediately put it back on) What would be the next part I should change?
May 11, 2009 at 10:57 AM
