1987 Ford Bronco
BRANDIMAR
  • 1987 FORD BRONCO
1987 Ford Bronco V8 Four Wheel Drive Automatic
how do I change my fuel filter?
Monday, March 29th, 2010 AT 7:41 PM
  • 109,885 POSTS
It should be mounted on the frame rail on the driver's side. It unclamps from its mount and then you just unbolt the fuel line going to each side and replace it with a new one.
NOTE: When you start to unbolt it, there may be fuel pressure in the line that will cause gas to spray out. You may want to cover the filter with an old rag and protect your body, face, and eyes just in case.
Tuesday, April 20th, 2010 AT 1:31 PM
