1986 Ford Bronco
THEUSMARINE
  • 1986 FORD BRONCO
Brakes problem
1986 Ford Bronco 6 cyl Four Wheel Drive Manual
1986 Ford Bronco II, sticking front brakes after a few miles of driving. Have replaced master cylinder and both calibers and pads. Brakes get reall hot and release after thirty minutes and rest.
Sunday, October 25th, 2009 AT 4:27 PM
  • 31,937 POSTS
HI there,
What you need to do first is to see if it is a pressure retention problem or a mechanical issue, with the brakes binding, crack the bleeder and see if this frees up the brakes, if so I would be suspecting restricted brake hoses and also check that the brake master cylinder has enough pedal free play, start here and report your findings.
Mark (mhpautos)
Sunday, October 25th, 2009 AT 7:51 PM
