Engine Mechanical problem
1984 Ford Bronco V8 Four Wheel Drive Automatic
how to set the timing correctly on a 84 5.8 351W 2barrel (elctronic controlled) carbed engine.
Friday, May 29th, 2009 AT 11:27 PM
MIKE H R
MECHANIC
The 351w up until 1978 timing was 4 degrees before top dead center from 1979 up the engine is controlled by the electonic engine control that controls the timing, idle speed and mixture.
SPONSORED LINKS
Friday, May 29th, 2009 AT 11:52 PM
LDELEON84
MEMBER
Does this year have some sort of vacume advance?As I was told that it did and can't seem to find it. What is going on is that when I turn off the car it keeps runing for a second it does start good but has that jump. It also revs at 1500 rpm at park. Is there anyway to fix this? And how?
Saturday, May 30th, 2009 AT 12:22 AM
MIKE H R
MECHANIC
The sytem that it has is probably a tfi. It eliminates the conventional vacuum advance mechanism The module is mounted on the distributor base and can be identigfied by the part number information on the decal attached to the base. With it reving at 1500 rps. Try something and get some carb cleaner and clean the orface. If there is a bit of carbon buildup it would cause the car to trv higher than normali
Sunday, May 31st, 2009 AT 8:24 PM
LDELEON84
MEMBER
It's a new carb and always did it since install.
Sunday, May 31st, 2009 AT 11:06 PM
MIKE H R
MECHANIC
So its done this since the new carb was put on. Is the carb diferent than the one that was on there? If so try disconnecting the positive side of the battery and leave it off for a couple of minutes then reconnect. This should clear the information in the computer tfi. With most newer cars the car need to be deiven about 50 miles to completly reset all information. What kind of carb did you put on?
SPONSORED LINKS
Monday, June 1st, 2009 AT 8:40 AM
LDELEON84
MEMBER
Same carb, computer controled. And am pretty sure they did the pos dis, but I also did it. And same thing happens. I think I figured out the timing advance. Went and unpluged a wire that had a disconnect and timeing went down. So I am asuming this is my timeing advance set the timeing at 10* and reconnected the wire and runs great. Exept for the high idle. Wich I can't figure out.
Monday, June 1st, 2009 AT 8:52 PM
MIKE H R
MECHANIC
Whats the name of the carb? Is there a info tap attached to one of the screws on top of carb?
