HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Aspire
Drivetrain
Differential
Axle
Bearing
SPONSORED LINKS
1997 Ford Aspire
DANARCHER40
MEMBER
1997 FORD ASPIRE
Drive Train Axles Bearings problem
1997 Ford Aspire 4 cyl Front Wheel Drive Manual
I am getting a grinding where the left front axle goes into transmission, tire is wearing from wobble. Do I need new axle?
Monday, April 6th, 2009 AT 9:45 PM
BLACKOP555
MECHANIC
I would suspect a bad bearing since the tire is wobbling. And that can cause the axle to go out and cause the nosie you described.
Just because the axle is spinning off doesnt mean the wheel wilL!
SPONSORED LINKS
Tuesday, April 7th, 2009 AT 7:23 PM
Please
login
or
register
to post a reply.
Related Differential Axle Bearing Content
1997 Ford Aspire Cv Joint
I'm At The Point Of Pulling The Passenger Side Cv Joint Out Of The Tranny But It Hits A Solid Stop. The Other End Is Already Out Of The...
Asked by
bushpilot50
1 ANSWER
1997
FORD ASPIRE
SPONSORED LINKS
Rear Axle Seal Replacement
Axle Bearing and Rear Seal Replacement Rear 1/2 ton
Online car repair manuals
