Ford Aerostar Stumbles in warm weather
FORD AEROSTAR
BULLDOG90
This is an 1993 Aerostar XL with 202000 (true) mileage; auto trans 4.0 L big v6; all power equip. Came with heavy duty trailer pkg. Vehicle has run just fine until last spring & summer when it began to intermitantly display check engine light and stumble & hesitate at both high way speed (60 -70mph) and city speeds (30-45mph) usually for short period (3-5 minutes). Will quit at light if not taken out of gear. AC is broken so not a factor. Check engine light comes & goes. Have not been able to get light to stay on long enough to get to repair facility and read codes. Since this is an OBD1, no memory. Event is totally unpredictable except that higher outside temp is sure to see it happen. Can happen at start or sometimes 3/4 to 1 hr after start. WINTER COLD sees NO PROBLEM whatsover. I am fairly handy with repairs & diagnosis but I don't want to go on a random replacement marathon. I wonder about: coil;plugs;wires;fuel pump; mass air sensor. Plugs have been replaced regularly. Fuel filter has been replaced twice last summer. Gas dryers have been added to fuel frequently. Gas cap seems to fit tightly. Wires are old as is cap & coil (only reason not replaced yet is NO PROBLEM in cold weather). I do understand that heat can cause electrical probs but problem is truly intermitent and unpredictable in duration. There are no current fluid :roll: leaks of any kind (have replaced heads 100k ago & hoses etc are current). Mass air sensor was replaced about 25K ago. I am uncertain what to look at next and would appreciate any help. Temperature is definitely the precipitator and the behaviour is as if fuel starved or ignition electrical breakdown. Any help is appreciated. Thanks.
Apr 12, 2007 at 6:25 AM
MERLIN2021
  • 17,250 POSTS
Even a 93 should store a trouble code...it's called the keep alive memory! Try reading the code koeo and koerunning! If you get anything but a 111 code you have found it! But it sounds like an egr fault...check the valve if it operates freely change the egr solinoid....if not change the valve. The other thing is have you ckecked for air leaks? especially around the throttle body? Some fords of that vintage had small cooler lines that run antifreeze thruogh it, make sure that's not leaking! The gaskets iside the throttle could be pourous.
Apr 12, 2007 at 6:40 AM
