1995 Ford Aerostar What is wrong with my air conditioner?
1995 FORD AEROSTAR
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
SPOOKYDUDE046
When I turn my a/c on in my 1995 Ford Aerostar van it blows warm air. I re-charged my a/c system, and still have the same problem. The belt will click in and shut off every couple of seconds. What could be wrong with my a/c?
Aug 3, 2008 at 1:36 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:681370afca="spookydude046"]Air Conditioning problem
1995 Ford Aerostar 6 cyl Four Wheel Drive Automatic 150000 miles
When I turn my a/c on in my 1995 Ford Aerostar van it blows warm air. I re-charged my a/c system, and still have the same problem. The belt will click in and shut off every couple of seconds. What could be wrong with my a/c?[/quote:681370afca]
The kicking in and out ever few seconds usually indicates low freon. When you recharged it did you check for leaks? If not your local auto parts store should have a can you can buy that is for finding leaks all you will need is a black light to find the leak or leaks.
Also check the Low Pressure switch that is located on the accumulator. Unplug the harness jump the terminals if clutch stays engaged few a while replace switch.
Aug 3, 2008 at 1:57 PM
