1995 Ford Aerostar replace brake lights
1995 FORD AEROSTAR
LUSTERKK
1995 Ford Aerostar 205000 miles
how do I replace the brake lights
Sep 22, 2009 at 7:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
are you replacing the brake lamp assembly or just needing to replace the brake lamp bulb ?
Sep 22, 2009 at 1:17 PM
LUSTERKK
brake light bulb needs replacing. I'm not for sure
you would change from the outside or inside the
trunk area.
Sep 24, 2009 at 4:46 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Replace it from the inside.
1. Remove the 4 screws holding the lens assembly to the vehicle. It may have a silicone or a sealer holding it in place, so if it does, slowly pull the assembly towards you as you cut away anything holding it in place after the screws are removed.
2. You can now remove the bulb assembly by holding firm the lamp assembly and twist counter clock wise the bulb socket then pulling straight out from the lamp assembly.
3. To remove the bulb socket from the lamp assembly, push in on the bulb, and twist it clockwise while pulling on it.
The bulb should now be removed.
4. Insert new bulb, twist clockwise to lock it into place.
5. Insert the bulb and socket assembly into the lens assembly and twist the socket clockwise to lock it.
6. Reinstall the lens assembly, then tighten lens assembly screws. Test lights.
Sep 24, 2009 at 5:26 AM
