Hi:
Is the engine running poorly, or are you trying to get more HP from it?
SPONSORED LINKS
Saturday, January 23rd, 2010 AT 11:34 PM
SHAN_97
MEMBER
A no I juss wanted it to have more speed and also hp
Friday, April 2nd, 2010 AT 10:12 AM
MECHANIC
We normally only deal with stock vehicles. As far as your question, there are many things you can get to increase HP. They make chips for the computer that can do wonders. Go to google and start looking for places that sell such items. The funny thing is, many times you'll get more HP and better fuel mileage.
Let me know if I can help.
Friday, April 2nd, 2010 AT 12:44 PM
SHAN_97
MEMBER
Im not sure if my dad is going to keep that car any longer alot of milage 250000 no accidents no technical problems or anything the back right wheel makes whitling sounds randomly and when you step on the breaks the power steering thing the noise is really annying only if those two things get fixed for under 500 dollars I would keep it cuz I dont wanna spend money on it When my dad got it the value was 24,000 13 years ago when I was born now its probably not even a 1,000 bucks ok can u tell me where I could repair the problems
for a cheap amount
Monday, June 7th, 2010 AT 12:18 AM
MECHANIC
Is the problem that the power steering is making noise or the rear brakes?
SPONSORED LINKS
Monday, June 7th, 2010 AT 7:31 AM
SHAN_97
MEMBER
Those are the problems steering noise and rear brake
Thursday, June 10th, 2010 AT 10:06 PM
MECHANIC
If the PS pump is making noise, first, check to make sure the resivour is full. If it is, all I can tell you is there were a lot of PS pumps replaced because they just went bad.
As far as the rear, do you only hear the noise when using the brakes? Can you describe the noise?
Friday, June 11th, 2010 AT 11:48 PM
SHAN_97
MEMBER
The noise sounds like a bird chirping fast randomly usally makes noise during braking
Saturday, June 12th, 2010 AT 2:43 PM
MECHANIC
I would recommend checking the rear brakes to make sure they are good, not worn, and have no broken hardware.
