1995 Ford Aerostar car queston
ANDREW THOMAS
  • 1995 FORD AEROSTAR
1995 Ford Aerostar
how do you put on a power stern pump on a 1995 ford Aerostar
Monday, November 3rd, 2008 AT 7:36 PM
  • 109,755 POSTS
Hi:
Disconnect the battery, remove the belt, remove both the hi and low pressure hoses, unbolt the PS pump and remove. Reverse sequence to replace. Also, you will need to fill the pump with PS fluid before starting. Once started turn the wheel until the pump begins to prim and refill the pump until it no longer goes down.
Thursday, November 27th, 2008 AT 11:05 PM
Related General Content
