1995 Ford Aerostar
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHADETREEMOBILE
cause of excessive n.o. reading.
Aug 20, 2010 at 12:45 PM
WRENCHTECH
  • 20,760 POSTS
If you are referring to NOX, that is caused by high combustion temperatures so anything that raises the combustion temps should be looked at starting with the EGR system. Make sure that is working good then look at ignition timing and engine temperature.
Aug 20, 2010 at 1:10 PM
