1994 Ford Aerostar
BRUNOS63
  • 1994 FORD AEROSTAR
  • 6 CYL
  • AWD
  • 189,000 MILES
Shuddering when engine is warm and gets worse after driving. Ridles ruff to when hot. Give a little throttle and it shutters all the time, no check engine light on, decreased power slow to pick-up speed. Thanks bruno
Wednesday, August 11th, 2010 AT 11:38 AM
  • 109,885 POSTS
Have you checked fuel pump pressrue and also, have you checked the catalytic converter to see if it plugged? When was the last tune up?
Friday, August 13th, 2010 AT 10:08 PM
BRUNOS63
I had a tune up a year ago, the fuel pressure regulator is 26to27lbspsi should be 35to45 with koeo, koerunning would that be it and how do you check the catalytic converter?
Saturday, August 14th, 2010 AT 9:17 AM
  • 109,885 POSTS
The fuel pressure is low which can cause power loss. As far as the converter, see if there are any noises such as ratteling, hissing. Noises coming from it with the engine on. When the engine is hot, check it to see if it is red hot. Also, feel if there is ample pressure coming from the tail pipe.
Saturday, August 14th, 2010 AT 11:28 PM
BRUNOS63
I guess I, M going to take it to a shop to much work for me I, M 65 AND can, t do alot thank you for the info, let me know if I owe you anything. BRUNO S
Sunday, August 15th, 2010 AT 9:56 AM
  • 109,885 POSTS
Glad to help. You owe us nothing. However, let us know if you have questions in the future, and pass our name along to friends.
Take care, and let me know what they find for you.
Sunday, August 15th, 2010 AT 9:47 PM
BRUNOS63
Ok joe and thanks again
Tuesday, August 17th, 2010 AT 9:45 AM
  • 109,885 POSTS
You're welcome.
Wednesday, August 18th, 2010 AT 1:10 AM
