1993 Ford Aerostar power steering repair
10,892 MILES • 6 CYL • 2WD • AUTOMATIC
VPARKER
Either the intake or outflow metal pipe at the pump is broken. Is this a huge job to repair, and what's your quess as to amount of cost? The reason I ask is the value of the vehical is less than $500. I have driven it less than two miles since the power steering went out.
Thanks, Vern
Dec 17, 2009 at 7:18 AM
  • 110,248 POSTS
If the steel line on the pump is broken, the pump will need replaced. The part is about 100.00 and the labor should be around 2 hours.
NOTE: Remember, you know what you have. What can you get with a few hundred dollars. Sometimes it's better to fix the vehicle if the rest of it is good.
Jan 23, 2010 at 3:37 PM
