1993 Ford Aerostar need to know how to turn the idler down
NICHOLEMAYHEW
MEMBER
1993 FORD AEROSTAR
4 CYL
FWD
AUTOMATIC
165,123 MILES
I need to turn the idiling down on my van its idling way to high and sucks gas and im not sure where the piece is
Tuesday, September 30th, 2008 AT 11:55 AM
THOMAS19290
MEMBER
Since your question is old, you may have found the answer. The manual I have says that the idle air control valve controls the idle speed, and no adjustment is possible. Get a repair manual from the library, to find out how to test it. The part is about $65.00 new, or less from a salvage yard. You'll probably have to show them where it's located, and what it looks like. Good luck.
