1989 Ford Aerostar heater blows cold
JOHBEY
  • 1989 FORD AEROSTAR
  • 6 CYL
  • 170,000 MILES
Why doesn't my heat work? Replaced the thermostat, reconnected the hose from the blower.
Wednesday, February 11th, 2009 AT 2:30 PM
  • 109,885 POSTS
Hi:
With the engine hot, running, and the heater on high, check to see if both heater core hoses are hot.
Let me know what you find.
Tuesday, February 24th, 2009 AT 9:44 AM
JOHBEY
Both heatercore hoses are hot and heater core also. Air blows over heatercore left to right but not comimng out hot. Checked control arms, moves damper ( little door behind heatercore) but still no hot air reaching heater vents
Sunday, March 1st, 2009 AT 7:44 PM
  • 109,885 POSTS
Are you sure the blender door is working. THat is what determins if you get heat or cool air.
Monday, March 2nd, 2009 AT 10:28 AM
JOHBEY
Where is it located and what position should it be in
Tuesday, March 3rd, 2009 AT 3:09 AM
  • 109,885 POSTS
It should be located on the same housing that the heater core is in. Exact position, I can't say but it should open and close when you change from cold to hot.
Tuesday, March 3rd, 2009 AT 10:12 AM
JOHBEY
Thanks there's a pen in there
Tuesday, March 3rd, 2009 AT 5:46 PM
