1988 Ford Aerostar 6 cyl Two Wheel Drive Automatic
I'm having a problem with my reverse, when gear is changed to "R" it gets reverse and then it gives out, then I go into Neutral go back to "R" it gets it again for about a sec. Then it goes out again. It's been like this for about a few months. The van itself shakes when turn into reverse, then you can hear a weird sound in between the transmission oil pump and the turbine. Any help. Cant figure out what the problem is.
SPONSORED LINKS
Thursday, April 8th, 2010 AT 5:19 PM
