1983 Ford Aerostar Gear shift
RONLOU
  • 1983 FORD AEROSTAR
  • 6 CYL
  • 98,000 MILES
I had my van in park, and when I came to put it in drive, the lever started to flop around whithout engaging the transmition. What could be broken it the system?
Wednesday, December 24th, 2008 AT 5:05 PM
  • 109,885 POSTS
Hi:
It sounds like the linkage to shift the trans has come apart. You will need to check under the hood and under the van to check for this problem. Have a helper move the lever while you check.
Tuesday, December 30th, 2008 AT 12:03 PM
