Flashing D light
227,052 MILES • 2.1L • 4 CYL • 2WD • AUTOMATIC
BLESSIN21
I noticed since of late that the D lights keep flashing. I took it to a auto shop and was told it could be that it needs a transmission flush. This was done and the light disappears, for a short time. It is now back again and I am sure that flush may have not been needed. How else can I proceed with this? Was doing some readings and I am seeing it could even a sensor or something of that sort. Please assist.
Aug 24, 2017 at 10:53 PM
  • 55,710 POSTS
These cars had a big problem with the shaft speed sensors which make the D light flash, to be sure you will need to read the codes here is a guide to help you:
Here is a video of the replacement:
https://youtu.be/f3bETtCIdxM
Please run this test and get back to us so we can keep helping you.
Cheers, Ken
Aug 26, 2017 at 4:44 AM
