flasher relay
222,000 MILES • V8 • 4WD • AUTOMATIC
MELODY ROACH
I changed the flasher relay and now when my engine is on there is a constant clicking that sounds like the turn signal is on even when it is not. the flasher relay was located on my passenger side kick panel where some fuses are located.
Jun 26, 2017 at 3:21 AM
  • 55,818 POSTS
While the clicking is going on put your hand on the flasher unit to see if that is what it is, if so then it is defective and you will need another one.
Cheers, Ken
Mar 29, 2021 at 5:25 AM
