Enter your question. I need the firing order on a ford f150 5.4, looking for cylinder 2
Thursday, June 16th, 2011 AT 10:00 PM
MECHANIC
Here is the engine ignition firing order in the diagrams below. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
SPONSORED LINKS
Thursday, June 16th, 2011 AT 10:13 PM
LARRY LOWE2
MEMBER
1 POST
2003 FORD F-150
4.2L
6 CYL
4WD
AUTOMATIC
233,000 MILES
Need to know spark plug wiring diagram.
Tuesday, December 1st, 2020 AT 11:37 AM
(Merged)
CATAFINA
MECHANIC
There you go, let me know if its not the one. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Images (Click to make bigger)
(Merged)
KEN L
MASTER CERTIFIED MECHANIC
Please let me know if you need anything else to get the problem fixed.
Best, Ken
(Merged)
CHADRICK RHEA
MEMBER
1 POST
2003 f150 4.2L
It is upside down but that is how I pulled it out. The plug goes on the passenger side.
SPONSORED LINKS
(Merged)
MECHANIC
Thanks for the addition to the site. I am sure that info will help others. Please let us know if there is something that we can assist you with in the future. You can start your own post here and we will jump in to assist with whatever you need. Thanks
I needa diagram of firing order of spark plug. Can u help me please
(Merged)
OBXAUTOMEDIC
MECHANIC
Firing order are the same on the 4.6l and the 5.4l v8 it is 1-3-7-2-6-5-4-8 and number one plug is on the front left as you face the engine
(Merged)
CASEYCOX
MEMBER
1 POST
2003 FORD F-150
Electrical problem
2003 Ford F150 6 cyl
Can you give me a firing diagram for my truck.
(Merged)
BMRFIXIT
MECHANIC
good luck
(Merged)
CHAPPY747
MEMBER
1 POST
2003 FORD F-150
Engine Mechanical problem
2003 Ford F150 6 cyl Two Wheel Drive
what is the firing order of a f-150 6 cylinder engine
Tuesday, December 1st, 2020 AT 11:38 AM
(Merged)
MECHANIC
Hi
Here is a picture and the firing order.
I hope this helps. If you have other questions, let me know.
SPONSORED LINKS
(Merged)
NESTOR68
MEMBER
1 POST
2004 FORD F-150
Problem on 2004 ford f-150 stx, shift it on drive, my engine dies. Diagnosed saying that misfiring on #1 cylinder, where is the #1 cylinder located at. Do I need to replace the coil and plug. Appreciated your generous help on me.
Thursday, December 3rd, 2020 AT 7:53 AM
(Merged)
BMRFIXIT
MECHANIC
(Merged)
PDBJBSMP
MEMBER
1 POST
2003 FORD F-150
V8
4WD
MANUAL
96,456 MILES
My truck was badly missing and the auto zone tester said #6 cylinder is not firing. Where do I find the #6 cylinder to check it
Monday, February 8th, 2021 AT 12:43 PM
(Merged)
JDL
MECHANIC
Welcome to the forum, not sure of engine litre size? The picture is for 5.4L engine.
