Fault codes on dash
150,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JOSHMARTIN806
Car is in limp mode however no fault codes are showing up on my scan tool. The code I am concerned with is a CCID420 code, not sure exactly what that means?
Nov 18, 2018 at 4:08 AM
  • 110,248 POSTS
The CC ID codes are indicators of issues the vehicle has. Some indicate a low tire, burned out bulb and other things. The CC ID 420 indicates a transmission malfunction. Hence, limp mode.
Now, that code is generic, meaning it could be many different things related to the transmission. At this point, I recommend either finding a scanner that can read transmission codes or taking it to a shop that has one. The only way I can go further is to know the more specific codes.
I wish I had an easier answer, but I do not.
Please feel free to ask more questions or let me know if you need additional help.
Nov 18, 2018 at 11:35 AM
