This is far more complicated than you are expecting. It is a two speed system that uses three relays to set up the speeds.
Here is the wiring diagram that you have to follow to track down the problem. Start with the basics of testing fuses.
SPONSORED LINKS
Saturday, August 6th, 2016 AT 5:14 AM
