Fan for heat and air conditioning
66,000 MILES • 1.7L • FWD • MANUAL
MOLLY6355
No longer blows air for the heater. Would this be a fuse? I turn the knob for the blower to come on for the heater in the car. No air blows out. Heat comes out but can not increase the blower to have more come out.
Jan 16, 2014 at 1:09 AM
  • 110,251 POSTS
If the blower motor isn't running, I would start by checking fuses.
Jan 16, 2014 at 2:44 AM
PRAVIN
This is mostly caused by corrosion on the terminals of the resistor pack, to access it you need to remove the vent just above the bonnet where your wiper and wiper motor is located, in the centre you will find a housing that houses your blower motor, remove the top cover of the housing and follow the path of the wires going into the housing which goes to a resistor pack and is held down by a screw, remove screw and resistor pack check connectors of resistor pack should be corroded and rusted, clean it off with sandpaper and lubricate contacts or replace unit, re-fitting is the reversal of removing.
Jan 21, 2014 at 4:08 PM
