Fail safe mode, no response from accelerator pedal
156,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JIMFARNSLEY
Engine starts and runs but I cannot accelerate.
Jan 3, 2019 at 3:14 PM
STEVE W.
  • 15,418 POSTS
The place to start would be with a scan tool. There are multiple items that can cause the car to go into limp mode. From a bad gas pedal to internal transmission failure. Without scanning it and seeing what it shows as a problem you could end up spending a lot of money and still not repairing it.
Jan 3, 2019 at 3:48 PM
  • 55,746 POSTS
I have seen a dirty throttle bore cause this issue creating a correlation loss between the actuator and sensor. I would disconnect the battery service the throttle bore then clear the codes and try it again. Here is a guide to help the service and a video to help clear the codes:
and
https://youtu.be/ahK_eucFi-k
Jan 4, 2019 at 10:54 AM
