exhaust questions
170 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BAN1
  • 9 POSTS
My truck would cut of or hesitates badly when you stomped it and i cut the mufflers out and it ran better. i then proceeded to gut the cats just to see if i could get a better result truck runs like a champ now. I am in the process of running true dual straight pipes on it.
Apr 27, 2016 at 11:42 PM
CARADIODOC
  • 34,414 POSTS
So you had a whole bunch of parts become plugged at the same time, and somehow the engine ran okay at times and cut out suddenly at other times? What exactly is the question?
Apr 28, 2016 at 8:03 AM
BAN1
  • 9 POSTS
when i bought the truck it ran fine other times when you would tromp down on the gas it would cut off. Also is there anyway to adjust a tbi?
May 5, 2016 at 10:44 PM
  • 55,694 POSTS
This can be one of two problems, either the fuel pressure is low due to a weak pump or plugged fuel filter. Or the ignition timing is off, here is a guide to check the fuel pressure.
http://.2carpros.com/articles/how-to-check-fuel-system-pressure-and-regulator
let me know what you find
Best, Ken
May 7, 2016 at 12:24 AM
BAN1
  • 9 POSTS
got the problem clogged return line
Jun 1, 2016 at 10:39 PM
  • 55,694 POSTS
I have never seen that before because it an open line what was it clogged with or was in bend or kinked?
Jun 2, 2016 at 10:58 AM
