Excessive mud underneath
128,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
WILLMEAD
Hello, I am not sure if this is an issue or not but upon inspection of a used vehicle, it was found that there was what I considered an unusual amount of dried mud on the underside. Is this a need to be concerned or is it something that just needs cleaning up?
Oct 13, 2021 at 11:28 PM
SQM
  • 6,383 POSTS
Generally speaking, having mud/dirt on the under carriage is not a big deal.
Unless of course the mud is due to the vehicle being in a flood/partially submerged.
Other possibility is that it has been driven off road. Keep in mind that when a vehicle which is not designed to go off road, goes off road, there are more chances of having damaged components.
Also, if it has been in water you want to make sure there is no damaged components, especially electrical.
My suggestion would be having the vehicle thoroughly inspected if you are thinking about purchasing.
Let me know of any questions or concerns.
Oct 14, 2021 at 12:57 AM
WILLMEAD
Thank you very much that information is greatly appreciated!
Oct 14, 2021 at 3:47 AM
SQM
  • 6,383 POSTS
You are welcome.
Oct 14, 2021 at 4:07 AM
