This is a gasoline engine correct? It is not offered in the USA so I just to make sure.
As for the amount of engine braking, you are correct that there will be some but if this is that bad, then I am hoping a video will help.
Can you get a video of just driving the speed it is the worst (in a safe place) and show the RPM when you are letting off the accelerator?
Also, I don't expect any codes but let's just make sure.
Then when you press the clutch in, the vehicle is fine? Thanks
Dec 25, 2020 at 10:57 AM
