EVAP system
1995 FORD F-150
199,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
BRADRENNIE
Charcoal canister overflowed while not running for several days, started right up but after a few blocks stalled.started right up but continues to stall after a short distance. Replaced stock inline fuel filter and vacuum line that leads to canister. Still starts right up but stalls after short distances.
Apr 7, 2017 at 4:19 AM
  • 55,433 POSTS
The charcoal canister has a valve on top that sounds like it has failed. This will pull raw gas into the engine and make it stall after a short time.
Please let us know what you find so it will help others.
Best, Ken
Apr 9, 2017 at 7:57 AM
JMF150
1998 Ford F150 V8 Two Wheel Drive Automatic
HI, I took my pickup for inspection and it failed. It came out with a Aveporative System NOT READY. No Codes.
Pls help
Apr 9, 2017 at 8:10 AM (Merged)
CRZYDRVR
  • 432 POSTS
take it to a repair shop that has a smoke machine that can help find very small leaks in the EVAP system.
JMF150
Thanks crzydrvr, I'll do that.
ASHISQUIERDO
Computer problem
2001 Ford F150 V8 Two Wheel Drive Automatic
the vehicle was smogged and a code was indicated 0456 Evap contol has a small leak.The engine light was illuminated and now it has gone out.
How and what tools are needed to check the evap system so this vehicle can pass smog
To catch this problem get the Evap system smoke tested
