Had a vent valve stuck open when testing so I bought a new one.tested the new one and worked good on bench. Tested for12 volts across connector in back of truck with key in and was good. Connected new valve and cycled key on and off and no click.Fabricated a 12volt tail light to test under load and when touching connector would not light up. Just had this surfacs 12 volts with nothing connected. What should I do next. I thought about running a wire from the battery negative terminal to the back with a known good ground and try touching the other lead to the positive side of the connector and see if it lights which would tell me maybe they negative side had an issue. What do you think. Also can't find a good schematic of thd wiring going back to fuse box or PCM. What do you think the issue could be. Thanks
Robert Walbroehl
Robert Walbroehl
Apr 29, 2026 at 11:02 PM
