Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
ATS
Emission
EVAP
Hole in EVAP line
2013 CADILLAC ATS
80 MILES • 3.6L • V6 • 4WD • AUTOMATIC
DAVID HEBNER
MEMBER
1 POST
My EVAP line has a pinhole in it and the part is going to take months to get here.
Is there a temporary fix?
Nov 19, 2018 at 6:36 AM
Experienced Mechanic
Honestly, the pressure in an EVAP hose is minimal. If you have located the hole, try using an automotive grade epoxy to seal it.
Also, in most cases, a small EVAP leak will not affect the performance of the vehicle.
If possible, let me know what code was set so I can get a better idea where in the system it may be located.
Nov 19, 2018 at 11:22 AM
Add image or video
Ask a new question
