Error Code P1320
2004 NISSAN SERENA
110,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
IMZIWA
i was given a Error Code P1320.
Suddenly the some days ago I drove the car on a 160 km trip, after moving about 120 km the car started failing to accelerate (sometimes there was only a delay in acceleration) every time I want to pick up or overtake a vehicle ahead this happened mostly right after slowing down. this behavior repeated until I reached my destination. the following day the behavior was the same, I moved about 140 km before it started delay and/or even fail to accelerate.
when that happens the brake is stiff, the accelerator is dump.
Jan 4, 2017 at 6:13 PM
  • 55,412 POSTS
Hey IMZIWA,
This code is for the ignition coil failure. I would start by replacing the spark plugs and clear the codes to see if it come back. Here are two guide that will help you.
https://www.2carpros.com/articles/how-to-change-spark-plugs
and
https://www.2carpros.com/articles/check-engine-light-clear-codes
Please let us know what you find so it will help others.
Best, Ken
Jan 5, 2017 at 5:35 AM
