Error Code P1153 - Manufacterer Control
204,000 MILES
UPMM019
  • 217 POSTS
So I bought a 2001 Chevrolet Suburban 1500 4wd LT.
When I got it there were many codes so thus far I have replaced an o2 sensor, plugs, wires, EGR Valve..... the suburban runs great but keeps throwing P1153 Manufacturer Control error code.
Looking for guidance on how to resolve this error code, if possible, DIY solution.
Nov 3, 2013 at 11:17 PM
SATURNTECH9
  • 30,869 POSTS
Which engine do you have?
Nov 3, 2013 at 11:55 PM
UPMM019
  • 217 POSTS
Engine Type 5.3L V8 16V OHV
Nov 4, 2013 at 12:00 AM
WRENCHTECH
  • 20,760 POSTS
Which 0/2 sensor did you replace because the one with the issue now is on the passenger side.
Nov 4, 2013 at 12:46 AM
UPMM019
  • 217 POSTS
I replaced the o2 sensor on the passenger side before the converter.
Nov 4, 2013 at 12:49 AM
WRENCHTECH
  • 20,760 POSTS
Did you clear the code after? Can you access the data stream to see what that sensor is doing?
Nov 4, 2013 at 1:02 AM
UPMM019
  • 217 POSTS
code has been cleared but i don't have anything to access the stream info.
I just have a cheap reader.
Nov 4, 2013 at 1:06 AM
UPMM019
  • 217 POSTS
After my last post I cleared the code and made it till today and the service engine came back on.... same darn code....
Nov 7, 2013 at 9:23 AM
