Hi all, what is the engine problem if error code #12 appear (from DTC)...tq
Nov 22, 2019 at 10:55 AM
✓Experienced Mechanic
A code 12 can be related to the ABS or the Cruise Control. Is there an engine issue? Also, did you mean a P0012? If you did, that deals with the camshaft position sensor.
