check Engine light on
250,000 MILES • 6 CYL • AWD • AUTOMATIC
CALICORYDER
Just had all six plugs changed out, on way home check engine light came on, ride started feeling rough, felt like it was gonna die at every stop and acceleration , skipping and jumping rest of way home too late at night to have a code check. Can i still ride it to work in a.m.? I'm scared, did changing plugs screw it up? Help!
Aug 7, 2016 at 5:18 PM
RIVERMIKERAT
  • 6,106 POSTS
Make sure they installed the correct plugs and put the plug wires back on in the correct order. You'll also need to have it scanned for codes. Which engine does it have. There are 2 6 cylinders listed for that year.
Aug 7, 2016 at 11:48 PM
