Engine vibration
2012 MERCEDES BENZ VITO
130,000 MILES • 2.2L • AUTOMATIC
BUBBLE 13
I have the car listed above it is a 113 CDI Taxi. When i put it into reverse or drive i get a big vibration and shaking for a couple of seconds and then it drives fine. This happens almost every time I put it into gear and has also cut out a few times. My garage have put the diagnostic machine to test this but no faults are showing.
Nov 19, 2017 at 9:28 PM
  • 110,240 POSTS
If there are no misfire codes, I question if the torque converter clutch is going bad. When it happens, take notice if the rpm's drop and in a safe place, place it in gear and see if it wants to move. I would also make sure the transmission fluid is clean and full.
Nov 20, 2017 at 9:12 AM
BUBBLE 13
There is not really a drop in rpm's. It does want to move when in gear but not too fast. Should I try a gearbox service as I think I am overdue? If it is still doing this after the service can I assume it is the torque converter?
Nov 20, 2017 at 8:59 PM
  • 110,240 POSTS
I never like to assume. If the vehicle is due for a service, it will not hurt to try.
Nov 21, 2017 at 12:01 PM
