engine very very tight after reaching normal operating temp
1989 MITSUBISHI MIGHTY MAX
100 MILES
WIRETWISTER
89 Max 2.0 truck, having a major issue after installing a rebuilt short block.
long story short.....when cold, engine turns over normal and runs just fine.
THE BAD....after engine reachs normal operating temp...Upon turning the engine off, the motor is to tight to turn over, its is basicly locked.
I even tryed to put a wrench and a pry bar on the crank ...im a big fellow and I cant budge it.
let it cool for a hour or so....cranks and runs fine.
What the heck is the problem ????
** here is what i know, I have drove it 75 miles, I put a real oil preasure gauge in and oil preasure is within spec, no overheating, not a starter issue, I removed the oil filter and cut the outer skin off which revealed no metal at all **
Now, What the heck is wrong....Im at a loss !!
Oct 1, 2013 at 11:58 AM
MADMIKE1735
  • 951 POSTS
if you pull all the spark plugs out, you eliminate any compression.... should be very easy to turn over.... sounds to me when its getting hot, something is binding/seizing up, and may take some disassembly to be certain what it is....
Oct 1, 2013 at 12:23 PM
MADMIKE1735
  • 951 POSTS
have you made any progress on this?
Oct 4, 2013 at 9:51 AM
DEREK WILLIAMS
Did anyone ever figure out the issue? My 2.4 is doing the exact same thing. I replaced the starter and it didn’t change anything. But mine don’t have to set too long to restart. Like if I shut it off to order food at drive thru it hesitates to restart. But it will. If I let it set 15 minutes or so it does not even hesitate.
Mar 17, 2021 at 7:37 PM
  • 110,240 POSTS
Nothing has been left as a repair. What exactly does your vehicle do? Is it possible for you to record what it does and upload it for us to hear? Also, what type of climate do you live in. Is it extremely hot? Is this something that started all at once?
Let me know as much as you can think of that may help.
Mar 20, 2021 at 3:23 PM
