Intermittent engine sputtering and backfiring when accelerating?
175,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
GSILVA
  • 5 POSTS
My truck sputters and backfires sometimes when i try to accelerate, and other times i can accelerate with no problem. So far i have done the following, i have changed the ignition coil, plugs and wires, EGR valve, checked MAP sensor, cap and rotor button, new fuel pump and filter, cleaned fuel injectors, timing is dead on the mark. It idle rough i suspect that i have a burnt valve, what are your thoughts?
Sep 21, 2023 at 2:27 AM
  • 110,248 POSTS
First, check to see if there are diagnostic trouble codes stored. Here is a link that explains how it's done. All you will need is a short jumper wire or even a paper clip.
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Now, take a look through this link that discusses the causes of backfires. See if anything helps.
https://www.2carpros.com/articles/engine-backfires-while-running
Since you have a rough idle, it could be a vacuum leak. A lean fuel mixture due to a leak can cause this to happen as well.
Here is a link that explains how to locate a leak:
Let me know if there are codes stored or if you find any vacuum leaks. make sure to check the intake manifold for possible vacuum leaks.
Sep 21, 2023 at 1:54 PM
GSILVA
  • 5 POSTS
Thank you for sending a reply to my question about my truck. I have not had a chance to look at everything you, sent me yet, but as soon as I get A chance to check, I will let you know what I found out. Thank you.
Sep 28, 2023 at 10:02 AM
