engine swap
1994 PONTIAC FIREFLY
200,000 MILES
HTLOGAN
swaped a 1996 1.0 lt 3 cyl engine with a crank sensor to a 1994 that had no crank sensor wired in the harness.
the motor starts up and idles perfect but will not rev up it starts sputering and even will backfire a little , is this bcause of the
crank sensor not being conected or should the motor run good without it , i swaped the intake manifold to match the wiring
harness can you help
May 20, 2013 at 12:38 PM
yes, the issue is the wiring harness. it needs a crank sensor to operate correctly
May 20, 2013 at 12:45 PM
MAXIMILIAM
  • 436 POSTS
Reply from htlogan via email:
hi there, what can i wire in the crank sensor to cause there is no wire coming in from the computer on the 1994 firefly, the sensor is on the motor and i have the wires,,can you help?
May 21, 2013 at 4:46 PM
you cannot wire in a crank sensor. It has to be part of the harness. You changed from obd 2 to obd 1. thats the real issue. Where is the crank sensor located??
May 22, 2013 at 9:28 AM
