Engine surging
101,000 MILES • 2.9L • 6 CYL • FWD • AUTOMATIC
DOWNRIVER
  • 7 POSTS
This car will start to surge after it has warmed up. There are no issues with the car prior to warm up. The engine gently surges when cruising between 30 and 45 mph. There is no surge at highway speeds. The tachometer will show a constant acceleration and deceleration when cruising at these speeds.
Check engine light is on.3 codes: P0036, P0442, P0136
The airbag light is on and that happened when the guys recovered my seat and unplugged the airbag connection line.
An alarm system needs servicing occasionally shows up and the service light does the same.
I replaced the sparks plugs since this started happening but have done nothing else. All hoses appear to be in good shape and connected properly. I did notice that the plastic tubing that covers the wires in many places is beginning to disintegrate.
Other than the engine surging the engine runs very well and the gas mileage has not changed.
Nov 18, 2016 at 8:20 AM
JOHNNY G.JR
  • 320 POSTS
does it surge when cruise control is on?
Nov 18, 2016 at 9:04 AM
DOWNRIVER
  • 7 POSTS
Have not tried cruise at these speeds. I will check that today. What if the answer is no?
Nov 18, 2016 at 7:11 PM
DOWNRIVER
  • 7 POSTS
Drove the car today and everything was fine until it warmed up. The surges began a short time later. When I switched on the cruise control it behaved the same way. Surging about 500 rpm's and then backing down again.
I failed to mention in my initial post that when the surges begin, the throttle will have an area where the engine does not respond until it is almost on the floor.
Nov 20, 2016 at 1:44 AM
  • 55,711 POSTS
Hey Downriver,
The first code is the secondary o2 sensor behind the catalytic converter is bad, I would start there, Also after you are done with that here are some services you can do to help the problem.
https://www.2carpros.com/articles/check-engine-light-clear-codes
and
and
https://www.2carpros.com/articles/mass-air-flow-service
Please let us know happens so it will help others.
Best, Ken
Nov 20, 2016 at 9:16 AM
DOWNRIVER
  • 7 POSTS
Cleaned MAF sensor, checked for vacuum leaks and found none. My OBD sensor says there is one O2 sensor and it is operating but I know there are 4. I checked the sensor electrical lines and they appear to be good. Not sure if I should start replacing sensors. Car runs the same as it did before.
Dec 4, 2016 at 11:23 PM
  • 55,711 POSTS
Hey Downriver,
When was the last time you replaced the spark plugs? Check the air filter to make sure it is not plugged and check for cracks in the intake boot.
Plus sometime cleaning the MAF doesn't do the trick and it must be replaced.
Also we have a Volvo tech on our team I will see if he can help us out here. I sent him a message.
I will watch the thread to make sure we get the problem fixed.
Best, Ken
Dec 5, 2016 at 3:16 AM
DOWNRIVER
  • 7 POSTS
Thank. Just changed the plugs. 100k on the original ones. The air cleaner is fine and the intake boot also.
Dec 5, 2016 at 4:26 AM
JIS001
  • 3,412 POSTS
The o2 sensor fault looks like it is the one behinde the right side cat (passenger side) and PO442 is for your cat efficiency. Check the CAT to see if is plugged up or broken.
Dec 5, 2016 at 5:11 AM
JIS001
  • 3,412 POSTS
Also forgot to ask. Do you have a turbo charger on these?
Dec 5, 2016 at 5:44 AM
  • 55,711 POSTS
There is my Volvo tech! we rock.
Dec 5, 2016 at 7:45 AM
DOWNRIVER
  • 7 POSTS
This is a 2.9l non turbo
Dec 5, 2016 at 9:58 AM
JIS001
  • 3,412 POSTS
Ok thanks. Then have the catalytic converter checked to see if it broke inside.
Dec 5, 2016 at 10:33 AM
DOWNRIVER
  • 7 POSTS
I haven't had the cat checked yet but the problem has changed a little. The surging is only at very low speeds now. About 15 mph. I rarely drive this slow so I have little motivation to take this in. The Volvo dealer is not close and they usually want to do more repairs than the blue book value of the car. The throttle position problem still happens occasionally and I wonder if should go ahead and replace the sensor or do you think this all relates back to the cat?
Dec 19, 2016 at 6:07 PM
  • 55,711 POSTS
This sounds like a sensor problem, it might be time to replace it.
Best, Ken
Dec 20, 2016 at 2:18 AM
