engine stopped, steering stuck and brakes stuck (cannot be pressed)
1998 MERCURY MYSTIQUE
6 CYL • AUTOMATIC
HAPPENING88
  • 8 POSTS
My car was getting near a stop sign and the engine stopped, steering locked and brakes were stuck (could not be pressed).
It would just keep on going. I had to apply emergency brake. once stopped, I removed keys and tried to start again and it worked. CAN anyone help me and know what could be the issue here. it is 98 mercury mystique. 4 cylinder, auto trans. Would really appreciate your response
Jan 9, 2015 at 5:39 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Has it done it again? Has the check engine light come on?
As far as the brakes and steering, the power assist brakes are actuated by engine vacuum. If the engine stalls, that vacuum is lost. The brakes will still work, but you will have to push much harder. The steering is assisted hydraulically by a pump. If the engine stalls, the pump stops and it becomes manual steering (very hard to turn).
Let me know if it has done it again or the check engine light has come on again.
Jan 9, 2015 at 7:38 PM
HAPPENING88
  • 8 POSTS
thanks for response. after restarting car. it has been working fine. no issues. This same thing happened a year ago. it just happened once. nothing was done about it and it has worked fine ever since. You still think this is related to engine? is it this worth fixing?
Jan 10, 2015 at 6:21 AM
  • 110,190 POSTS
I feel the engine stalling is the cause of the steering and brake issues. As far as fixing it, if it is running good again, that makes it hard because it won't show any codes or problems. With this kind of situation, (and I hate to say this) you have to wait until it won't restart. At that point, you will be able to find the problem.
As far as "is it worth fixing?" If the car has been reliable, is in good condition... my suggestion is yes, it is worth fixing unless you end up with a huge bill. The way I try to explain it is like this. If you had to put 1000.00 dollars into it, at least you know what you have. If you spent 1000.00 on a used vehicle, you have no idea what you are getting or what it needs, and frankly, how good of a car can you get for that price.
Keep that in mind when you need to put money into your present vehicle. Yes, there will come a point where too much is being put into it. At that point, it may be time for a new one.
Jan 12, 2015 at 5:52 AM
HAPPENING88
  • 8 POSTS
I got autozone to read the codes. they said 3 out of 6 cylinders are misfiring (1,3,5). They said i would have to replace the spark plugs. Do you think misfiring could be the reason for the issue it was caused.
I really appreciate your help.
Jan 12, 2015 at 8:05 PM
  • 110,190 POSTS
Yes, a 3 cylinder misfire would cause it to stall. However, I don't think the spark plugs are the problem. Since 1. 3. and 5 cylinders are all misfiring, there is a good chance it is a coil issue. By any chance, did they tell you the codes they found? Based on what you told me, they should have found P0301, P0303, P0305. Were there any others?
Jan 13, 2015 at 5:56 AM
