We don't have a manual on this vehicle as it is not offered in the USA so it is hard to know for sure due to not being able to see how the engine operates.
However the obvious things to check are oil levels and to make sure you have the correct filter installed.
The next thing we need to do is check oil pressure and see if it is dropping when this is going to stall. Clearly once the engine does stall it should drop but not before. Let us know what you find. Thanks
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jun 17, 2020 at 6:21 AM
