2.4L MY ENGINE SHUTS DOWN AS SOON AS IT GETS TO RUNNING TEMP....IVE REPLACED BELTS,BATTERY,RADIATOR TEMP SENSOR, FAN,THERMOSTAT PLUGS AND WIRES ALTERNATOR,AND STILL SAME PROBLEM......THANKS AND GOD BLESS YOU.....P.S. IT WONT START AGAIN AFTER SHUTTING OFF ONCE IT GETS UP TO RUNNING TEMP UNLESS IT COOLS ALL THE WAY BACK DOWN????THEN IT STARTS AND RUNNS FINE UNTIL IT GETS HOT AGAIN THEN OFF IT GOS AND WONT START BACK UP...IT WILL CRANK JUST WONT RUN...
Aug 25, 2013 at 3:20 AM
