Engine shaking
2010 CADILLAC SRX
104,000 MILES • 1.3L • V6 • TURBO • AUTOMATIC
ILOVELIFE
The engine is starting to rattle. And I just had a hub bearing put on. However, I have no lights indicating that something is wrong.
Jun 13, 2019 at 8:35 AM
Hi ILOVELIFE,
An engine rattle could be a number of different things. Can you give a little more detail about when it does this? Is it just a noise or does it run rough? Also, is it only while driving or sitting still?
I just am not sure the correlation between the hub bearing and an engine rattle so I need a little more info to go on.
If it is something that a video would demonstrate better, then feel free to get a video of it and post it so we can get on the same page. Thanks
Jun 13, 2019 at 9:43 AM
ILOVELIFE
It’s shaking while driving and at first there were no lights now I have a light.
Jun 13, 2019 at 10:05 AM
Okay. I suspect you have a misfire or a vacuum leak. We need to start with getting the codes that are there and are the reason for the light to be on.
If you don't have a scan tool that can pull the codes, most parts stores can pull them for you free of charge. If you can get me those, we can narrow this down.
Jun 13, 2019 at 10:15 AM
