Engine replacement
2011 NISSAN VERSA
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUDOE13@GMAIL.COM
Check engine light flashing then solid. Was told due to misfire. Had tune up done. Changed oil. No mixing of oil and water. After dealership checked car said I needed engine replaced. Now car will not go past twenty five mph to get past second gear without check engine light flashing. Any other possible reasons besides an engine replacement?
Mar 10, 2018 at 9:12 PM
  • CERTIFIED EXPERT
  • 31,937 POSTS
can you post the codes set so i can see what is going on?
Mar 11, 2018 at 1:49 AM
